Help
Disassembling Canon PowerShot SD800 IS Back Cover
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Removing back cover.
  • Author: Jeremy Rabaino
  • Time estimate: 2 - 3 minutes
  • Difficulty: Very easy
Removing the back cover allows access to the LCD display and the flash assembly.
Step 1 Back Cover  ¶
Remove one 2.25mm screw on the bottom.
Step 1 Back Cover  ¶
  • Remove one 2.25mm screw on the bottom.
Step 2  ¶
Remove two 2.25mm screws on the right side looking from the front.
Step 2  ¶
  • Remove two 2.25mm screws on the right side looking from the front.
Step 3  ¶
Remove one 4.7mm screw on the side with the AV output.
Step 3  ¶
  • Remove one 4.7mm screw on the side with the AV output.
Step 4  ¶
Pull off the back cover.
Step 4  ¶
  • Pull off the back cover.
  • The back cover tends to stick in the top corner (near the mode dial) due to a metal clip. Jiggle the cover side to side as you pull it out.
