Help
dreamGEAR Quad Dock Pro Mother Board Replacement
Remove the mother board from the Quad Dock Pro
  • Author: Jacob
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
The motherboard is the heart and soul of any electronic device. Learn how to replace it!
Step 1 Mother Board  ¶
Remove the six screws holding the motherboard in. Two are 2mm PH0 screws (circled in orange), four are 1.8 mm J1 screws (circled in red). Remove the six screws holding the motherboard in. Two are 2mm PH0 screws (circled in orange), four are 1.8 mm J1 screws (circled in red).
  • Remove the six screws holding the motherboard in. Two are 2mm PH0 screws (circled in orange), four are 1.8 mm J1 screws (circled in red).
Step 2  ¶
Gently pick up the mother board
Step 2  ¶
  • Gently pick up the mother board
  • Pick the mother board straight up or you may risk damaging the mini-USB charging ports.
Step 3  ¶
Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port. Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
Step 3  ¶
  • Use a plastic opening tool or similar tool to gently pry the power ribbon cord out of its port.
