Help
Toshiba Satellite A75-S226 CD Drive Replacement
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
  • Author: Garrett Gudgel
  • Time estimate: 3 - 5 minutes
  • Difficulty: Easy
This a very simple guide to replace or remove the CD-ROM drive from your Toshiba Satellite A75-S226. Remember when repairing the internal components of an electronic device, a dry and clean environment is ideal.
Step 1 CD Drive  ¶
Remove the 8.6 mm screw. Remove the 8.6 mm screw. Remove the 8.6 mm screw.
Step 1 CD Drive  ¶
  • Remove the 8.6 mm screw.
Step 2  ¶
Push the bottom left corner of the CD Drive until the drive protrudes from the case. When a good amount of the CD Drive is showing on the right side, gently pull it out completely. When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
Step 2  ¶
  • Push the bottom left corner of the CD Drive until the drive protrudes from the case.
  • When a good amount of the CD Drive is showing on the right side, gently pull it out completely.
