Help
Samsung Galaxy Note 4 Motherboard Replacement
Replace the motherboard.
  • Author: Geoff Wacker
  • Time estimate: 30 minutes - 2 hours
  • Difficulty: Moderate
Use this guide to replace the motherboard in your Samsung Galaxy Note 4.
Step 1 Motherboard  ¶
Remove the two 2.9 mm Phillips #00 screws.
  • Remove the two 2.9 mm Phillips #00 screws.
Step 2  ¶
Use a set of tweezers to remove the two antenna cables. Use a set of tweezers to remove the two antenna cables.
Step 2  ¶
  • Use a set of tweezers to remove the two antenna cables.
Step 3  ¶
Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors. Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors. Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
Step 3  ¶
  • Use a set of tweezers or the flat end of a spudger to disconnect the two ribbon cable connectors.
Step 4  ¶
Gently lift the motherboard out of the phone.
Step 4  ¶
  • Gently lift the motherboard out of the phone.
