Help
Canon PowerShot SD200 LCD Screen Replacement
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
This guide will show how to remove the LCD screen from the Canon PowerShot SD200.
  • Author: James Loy
  • Time estimate: 30 - 45 minutes
  • Difficulty: Moderate
The Canon PowerShot SD200 has a 2" LCD screen on the back of the camera. Removing the LCD screen might be necessary if it is damaged. This guide will show you how to remove the LCD screen.
Step 1 LCD Screen  ¶
Remove the one 2.4 mm Phillips screw from the bottom of the motherboard.
Step 1 LCD Screen  ¶
  • Remove the one 2.4 mm Phillips screw from the bottom of the motherboard.
  • Remove the two 3.9 mm Phillips screws from the top of the motherboard.
Step 2  ¶
Remove the one 2.4 mm Phillips screw directly above the top right corner of the LCD screen.
Step 2  ¶
  • Remove the one 2.4 mm Phillips screw directly above the top right corner of the LCD screen.
Step 3  ¶
Use the flat end of the spudger to lift up the small black connector from the back side of the motherboard. The connector should just lift straight up. Use the flat end of the spudger to lift up the small black connector from the back side of the motherboard. The connector should just lift straight up.
Step 3  ¶
  • Use the flat end of the spudger to lift up the small black connector from the back side of the motherboard. The connector should just lift straight up.
Step 4  ¶
Hold the camera at an angle to locate the small blue ZIF connector on the back side of the motherboard and next to the LCD screen. Use the flat end of the spudger to flip up the tab of the  blue ZIF connector. Slide the ribbon cable out.
Step 4  ¶
  • Hold the camera at an angle to locate the small blue ZIF connector on the back side of the motherboard and next to the LCD screen.
  • Use the flat end of the spudger to flip up the tab of the blue ZIF connector. Slide the ribbon cable out.
  • Once the ribbon is removed, the LCD screen can be rotated away from its initial position to reveal more screws underneath.
  • Do not pull the LCD screen out or rotate past 180 degrees away from its initial position, or else you will damage the remaining ribbon that holds the LCD sceen in place.
Step 5  ¶
Remove the four 2.6 mm Phillips screws located underneath where the LCD screen used to be. Remove the one 4.2 mm Phillips screw from the bottom of the back face of the camera.
Step 5  ¶
  • Remove the four 2.6 mm Phillips screws located underneath where the LCD screen used to be.
  • Remove the one 4.2 mm Phillips screw from the bottom of the back face of the camera.
Step 6  ¶
Remove the one 2.7 mm Phillips screw from the left side of the camera.
Step 6  ¶
  • Remove the one 2.7 mm Phillips screw from the left side of the camera.
Step 7  ¶
Using the flat end of the spudger, begin to slightly peel back the orange ribbon cable from the rest of the camera by lifting up at the bottom corner. The ribbon cable should pop off of the pegs. Rotate the speaker so that it unlatches from the camera frame. Then use the flat end of the spudger to lift up the speaker from the rest of the camera.
Step 7  ¶
  • Using the flat end of the spudger, begin to slightly peel back the orange ribbon cable from the rest of the camera by lifting up at the bottom corner. The ribbon cable should pop off of the pegs.
  • Rotate the speaker so that it unlatches from the camera frame. Then use the flat end of the spudger to lift up the speaker from the rest of the camera.
Step 8  ¶
Use the flat end of the spudger to  peel back the orange ribbon cable on the top of the camera where the power button contact is located. Only apply enough force to lift the power button contact up from the rest of the camera. Use the flat end of the spudger to lift up the LED bulb from the rest of the camera.
Step 8  ¶
  • Use the flat end of the spudger to peel back the orange ribbon cable on the top of the camera where the power button contact is located. Only apply enough force to lift the power button contact up from the rest of the camera.
  • Use the flat end of the spudger to lift up the LED bulb from the rest of the camera.
Step 9  ¶
Rotate the camera upside down to locate the small black ZIF connector located in the middle of the camera. Use the flat end of the spudger to flip up the tab on the black ZIF connector. Pull the ribbon cable straight out.
Step 9  ¶
  • Rotate the camera upside down to locate the small black ZIF connector located in the middle of the camera.
  • Use the flat end of the spudger to flip up the tab on the black ZIF connector. Pull the ribbon cable straight out.
  • Remove the orange ribbon cable from the rest of the camera.
Step 10  ¶
Remove the one 4.3 mm Phillips screw that is now visible, which is located at the top right of the back of the camera.
Step 10  ¶
  • Remove the one 4.3 mm Phillips screw that is now visible, which is located at the top right of the back of the camera.
Step 11  ¶
Locate the two ZIF connectors on the front of the camera. Use the flat end of the spudger to flip up the tab on the blue ZIF connector. Then pull the ribbon cable straight out. Use the flat end of the spudger to flip up the tab on the black ZIF connector. Then pull the ribbon cable straight out.
Step 11  ¶
  • Locate the two ZIF connectors on the front of the camera.
  • Use the flat end of the spudger to flip up the tab on the blue ZIF connector. Then pull the ribbon cable straight out.
  • Use the flat end of the spudger to flip up the tab on the black ZIF connector. Then pull the ribbon cable straight out.
Step 12  ¶
Lay the camera on its front side.
Step 12  ¶
  • Lay the camera on its front side.
  • Hold down on the camera's metal casing with one hand. Using your other hand, lift the LCD screen straight up, making sure the LCD screen's ribbon cable slides free of metal casing.
  • When reassembling, the LCD screen ribbon cable must go through its slot in the metal backing before attaching the back metal casing.
