Help
Panasonic Lumix DMC-TZ5 Front Cover Replacement
This guide will show you how to replace the front casing of your Panasonic Lumix DMC-TZ5.
  • Author: Kevin Lufkin
  • Time estimate: 30 - 35 minutes
  • Difficulty: Moderate
The front casing is the frontal frame on your Panasonic Lumix DMC-TZ5. All the major components of the camera are attached to this front casing.
Step 1 Front Cover  ¶
After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • After removing the AV circuit board you are left with the front casing attached to the inner casing and flash unit.
  • First you must remove two 3.5mm blue screws near the hole of the lens that attach the inner casing.
Step 2  ¶
Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
Step 2  ¶
  • Remove the 3.5mm colorless screw that lays within the square opening of the inner casing.
Step 3  ¶
Remove the front casing from the rest of the device.
Step 3  ¶
  • Remove the front casing from the rest of the device.
