Help
iPod 2nd Generation Display Replacement
  • Author: iRobot
  • Difficulty: Moderate
Replace a cracked or faulty display.
Sections
Step 1 Display  ¶
Lift the blue hard drive mounting bracket out of the iPod.
Step 1 Display  ¶
  • Lift the blue hard drive mounting bracket out of the iPod.
Step 2  ¶
Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Step 2  ¶
  • Carefully disconnect the white battery connector from the logic board. Be sure to pull only on the connector itself and not on the cables.
Step 3  ¶
Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
Step 3  ¶
  • Like the hard drive connector, for the following step, you only need to move the connector about 2 mm. Pushing too hard or too far will damage the connector.
  • Loosen the touch wheel connector by pulling the brown locking bar toward the side of the iPod using the tips of your fingers.
Step 4  ¶
Remove the 8 T6 Torx screws from the logic board.
Step 4  ¶
  • Remove the 8 T6 Torx screws from the logic board.
Step 5  ¶
Lift the logic board up enough to disconnect the orange touch wheel cable.
Step 5  ¶
  • Lift the logic board up enough to disconnect the orange touch wheel cable.
  • Lift the logic board out of the iPod.
Step 6  ¶
Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
Step 6  ¶
  • Note the location of the four white plastic tabs securing the display to the logic board. These tabs must be released before the display can be removed.
Step 7  ¶
Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
Step 7  ¶
  • Use a spudger or your finger to free the four white plastic tabs indicated in the previous picture.
Step 8  ¶
Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
Step 8  ¶
  • Use a spudger to carefully disconnect the display ribbon cable from beneath the scroll wheel.
  • Lift the display off the logic board.
