Help
Disassembling DeWalt D28110 Back Panel Disassembly
The back panel holds most of the small electrical components that might need to be replaced.
  • Author: Kean Wee
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
Prerequisite Only
Step 1 Disassembling DeWalt D28110 Back Panel Disassembly  ¶
Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  • Using the T-15 screwdriver, remove the four 22-mm torx screws holding the back panel in place.
  • Unplug the grinder before any disassembly.
Step 2  ¶
Use the edge of the spudger to loosen and remove the back panel.
Step 2  ¶
  • Use the edge of the spudger to loosen and remove the back panel.
Step 3  ¶
Remove the single 20-mm torx screw holding the rear panel in place.
Step 3  ¶
  • Remove the single 20-mm torx screw holding the rear panel in place.
Step 4  ¶
Pull back the rear side of the back panel.
Step 4  ¶
  • Pull back the rear side of the back panel.
