Help
Asus VivoBook Q200E-BSI3T08 Back Panel Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Removing the back panel will be necessary for replacing other major components of the laptop such as the battery.
  • Author: Raveena
  • Time estimate: 1 - 3 minutes
  • Difficulty: Very easy
This guide will help with removing and/or replacing the back panel.
Step 1 Back Panel  ¶
Turn off the computer and unplug the charge cable.
Step 1 Back Panel  ¶
  • Turn off the computer and unplug the charge cable.
  • If the computer is on or plugged in, it could cause electric shock.
  • Turn the computer upside down.
Step 2  ¶
Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
Step 2  ¶
  • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
Step 3  ¶
Use a plastic opening tool to gently remove the back panel. Use a plastic opening tool to gently remove the back panel.
Step 3  ¶
  • Use a plastic opening tool to gently remove the back panel.
