Help
Microsoft Band Wrist Clasp Replacement
This guide will safely replace the spring clasp system.
  • Author: Chad Steese
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
You might try keeping track of the screws with the use of a magnetic mat.
Step 1 Wrist Clasp  ¶
Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
  • Using the T3 Torx Screwdriver, remove the two 2.00mm long screws from the inside of the clasp.
Step 2  ¶
Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
Step 2  ¶
  • Remove the metal plate with the serial and model number on it by pulling it straight up around the two hooks.
Step 3  ¶
Pull the two securing pins out of the rubberized part of the band.
Step 3  ¶
  • Pull the two securing pins out of the rubberized part of the band.
