Help
Disassembling Panasonic Lumix DMC-TZ5 Back Cover
This is the start to every repair guide, removing the back casing which also contains the LCD Display and back buttons.
  • Author: Ben Canfield
  • Time estimate: 5 minutes
  • Difficulty: Easy
Since this is step one, you will just need to start with your camera.
Step 1 Back Cover  ¶
Remove the battery and memory card from the device.
Step 1 Back Cover  ¶
  • Remove the battery and memory card from the device.
Step 2  ¶
Remove 4 screws from the right side of the camera.
Step 2  ¶
  • Remove 4 screws from the right side of the camera.
  • There are two 3.4mm screws at the top.
  • There are two 2.2mm screws at the bottom.
Step 3  ¶
Remove the single 3.4mm screw on the left side of the camera.
Step 3  ¶
  • Remove the single 3.4mm screw on the left side of the camera.
Step 4  ¶
Remove 5 screws from the base of the camera.
Step 4  ¶
  • Remove 5 screws from the base of the camera.
  • There are two 2.2mm screws next to the battery compartment.
  • There are three 4mm screws around the tripod mount.
Step 5  ¶
Slowly slide the back cover away from the device
Step 5  ¶
  • Slowly slide the back cover away from the device
  • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
Step 6  ¶
Detach both ribbon cables using a spudger. Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Step 6  ¶
  • Detach both ribbon cables using a spudger.
  • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
Step 7  ¶
Remove the back casing from the camera.
Step 7  ¶
  • Remove the back casing from the camera.
