Help
Geardup RC Ford Mustang GT Car Battery Replacement
Use this guide to replace the batteries for the GEAR'D UP RC Ford Mustang GT.
The batteries power the car and allow it to run. If it isn't running, try using the following steps to replace the batteries.
Step 1 Battery Cover  ¶
Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels. Gently lift the battery cover from the car to expose the batteries. Gently lift the battery cover from the car to expose the batteries.
  • Remove the 5mm Phillips #0 screw from the bottom of the car, located between the rear wheels.
  • Gently lift the battery cover from the car to expose the batteries.
