Help
Motorola Moto G 2nd gen. 2014 Battery Replacement
Archived Guide
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
Member-Contributed Guide
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
  • Author: Sophia
  • Time estimate: 10 - 45 minutes
  • Difficulty: Moderate
Step 1 Battery and SIM&SD Card Reader  ¶
Remove back cover. Remove back cover.
  • Remove back cover.
Step 2  ¶
Unscrew 14 screws and remove the back frame. Unscrew 14 screws and remove the back frame. Unscrew 14 screws and remove the back frame.
Step 2  ¶
  • Unscrew 14 screws and remove the back frame.
Step 3  ¶
Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator. Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator. Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator.
Step 3  ¶
  • Release SIM & SD card reader assembly connector and battery connector. Get loosen the vibrator.
Step 4  ¶
Loosen kinds of stickers fastening card reader assembly and battery. Loosen kinds of stickers fastening card reader assembly and battery. Loosen kinds of stickers fastening card reader assembly and battery.
Step 4  ¶
  • Loosen kinds of stickers fastening card reader assembly and battery.
Step 5  ¶
Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly. Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly. Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly.
Step 5  ¶
  • Remove the battery with card reader assembly together at first. And then separate them.The battery flex is stuck on the back of the card reader assembly.
Step 6  ¶
The battery can be replaced now.
Step 6  ¶
  • The battery can be replaced now.
