Help
Motorola Droid 2 Motherboard Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace a dead motherboard on your Droid 2.
Follow this guide to replace your Droid 2's broken or malfunctioning motherboard.
Sections
Step 1 Motherboard  ¶
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board. De-route the antenna cable by pulling it out of the metal clips along the side of the front case. De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
  • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Step 2  ¶
Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
Step 2  ¶
  • Peel the black rubber sheet covering the side button and display ribbon connectors on the motherboard.
Step 3  ¶
Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Step 3  ¶
  • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Step 4  ¶
Disconnect the  display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Step 4  ¶
  • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Step 5  ¶
Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
Step 5  ¶
  • Use the flat end of a spudger to remove the small black plastic piece stuck to the battery connector.
Step 6  ¶
Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
Step 6  ¶
  • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
Step 7  ¶
Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
Step 7  ¶
  • Carefully lift the motherboard from the front case and lay it next to the Droid 2, minding the keypad connector that is still attached.
  • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
  • Remove the motherboard from the Droid 2.
