Help
PlayStation 3 Motherboard Assembly Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Step 1 Motherboard Assembly  ¶
Pull the control board ribbon cable straight up and out of its socket on the motherboard.
  • Pull the control board ribbon cable straight up and out of its socket on the motherboard.
Step 2  ¶
Remove the two 12 mm Phillips screws securing the control board to the lower case. Remove the control board and its attached cable from the PS3.
Step 2  ¶
  • Remove the two 12 mm Phillips screws securing the control board to the lower case.
  • Remove the control board and its attached cable from the PS3.
Step 3  ¶
Remove the following eight screws securing the motherboard assembly to the lower case:
Step 3  ¶
  • Remove the following eight screws securing the motherboard assembly to the lower case:
  • Seven 12 mm Phillips screws (ph2)
  • One 30 mm Phillips screw
Step 4  ¶
Remove the control board bracket.
Step 4  ¶
  • Remove the control board bracket.
Step 5  ¶
Use the flat end of a spudger to pry the hard drive bay cover away from the lower case. Remove the hard drive bay cover.
Step 5  ¶
  • Use the flat end of a spudger to pry the hard drive bay cover away from the lower case.
  • Remove the hard drive bay cover.
Step 6  ¶
Lift the motherboard assembly out of the lower case.
Step 6  ¶
  • Lift the motherboard assembly out of the lower case.
