Help
Kodak EasyShare LS743 Camera Case Disassembly
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Replace outer casing.
  • Author: Michael
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
Remove damaged case and replace with new casing.
Step 1 Kodak EasyShare LS743 Camera Case Disassembly  ¶
Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
  • Remove 7 screws.
  • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
  • 4 (4.45mm) screws on the bottom of the camera.
  • 2 (2.95mm) screws on the left side of the camera.
Step 2  ¶
There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
Step 2  ¶
  • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
Step 3  ¶
Remove the rear camera casing. Remove the front casing.
Step 3  ¶
  • Remove the rear camera casing.
  • Remove the front casing.
