Help
Asus V6800V RAM Replacement
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
How to get to, remove, and reinstall the RAM
  • Author: Connor
  • Time estimate: 25 minutes
  • Difficulty: Moderate
Step 1 RAM  ¶
On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
Step 1 RAM  ¶
  • On the back panel unscrew highlighted screws and carefully put them to the side as not to lose them.
Step 2  ¶
Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
Step 2  ¶
  • Locate the RAM chip highlighted in Blue and the two metal tabs holding it in place highlighted in red.
Step 3  ¶
Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
Step 3  ¶
  • Carefully use your thumbs to push out the metal tabs and the RAM should spring up.
Step 4  ¶
After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
Step 4  ¶
  • After the ram has sprung up, carefully grab the edges with your fingers and gently pull straight out.
Step 5  ¶
After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
Step 5  ¶
  • After you have gotten either more RAM or replacement RAM line up the pins and slot (highlighted red) in the RAM card with the pin on the computer.
  • Carefully insert the new ram in at the same angle that you removed it at.
  • The other side of the RAM slot is a place for more RAM if you want to put more in. The spaces are highlighted in blue.
