Help
HTC EVO Design 4G Screen Replacement
Slice and Dice
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
In this procedure, you will be disassembling the HTC Evo Design 4G to replace its screen.
  • Author: Victoria
  • Time estimate: 15 - 30 minutes
  • Difficulty: Moderate
Step 1 Screen  ¶
Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
Step 1 Screen  ¶
  • Tools: Phillips #000 Screwdriver, T4 Torx Screwdriver, Safety Pry Tool (Guitar pick), Tweezers
Step 2 Removing Casing  ¶
Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
  • Use fingers on either end of the button edges of the phone to pull back cover off. It should slide off.
Step 3 Removing Battery  ¶
When open, pull on “Open” tab and  it should rotate towards you Grab the bottom edge of the battery and pull it toward you
  • When open, pull on “Open” tab and it should rotate towards you
  • Grab the bottom edge of the battery and pull it toward you
Step 4 Removing Casing  ¶
On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it Info*: The adhesive tape that you may find will not be necessary for replacement later
  • On the side of the top casing on the phone there should be a slot. Use your safety pry tool (guitar pick) pry around the perimeter of the casing to remove it
  • Info*: The adhesive tape that you may find will not be necessary for replacement later
Step 5 Removing Screws  ¶
Remove the two Phillips screws to release the casing above the port Remove the top and bottom pairs of Torx screws.
  • Remove the two Phillips screws to release the casing above the port
  • Remove the top and bottom pairs of Torx screws.
  • Remove the middle pair of two Phillips screws.
Step 6 Removing Casing  ¶
To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
  • To remove the remaining cover, lift the side port, which was previously uncovered, then lift the outer shell from the bottom of the phone and slide it forward
Step 7 Removing Screws Continued  ¶
Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
  • Remove the two revealed screws on the outside (Torx = red, Phillips = orange), and then remove the two phillips on the bottom of the phone
Step 8 Removing Rear Housing  ¶
Remove the rear housing by prying around the edge with your Safety Pry Tool Remove the rear housing by prying around the edge with your Safety Pry Tool
  • Remove the rear housing by prying around the edge with your Safety Pry Tool
Step 9 Pull the Plug  ¶
Unplug the wire connecting the vibrator to the board with your tweezers
  • Unplug the wire connecting the vibrator to the board with your tweezers
Step 10 Like a Book  ¶
Unfold motherboard from the screen (open carefully like a book)
  • Unfold motherboard from the screen (open carefully like a book)
Step 11 Flex Cables  ¶
Disconnect the two aluminum flex cables
  • Disconnect the two aluminum flex cables
Step 12 Broken Bond  ¶
The flex cables should be the only binding and after being removed should leave you with the separate screen
  • The flex cables should be the only binding and after being removed should leave you with the separate screen
