Help
Campbell Hausfeld FP204800 On/Off Switch Replacement
Replace the On/Off switch of your compressor so that you can safely regulate its use.
  • Author: Caleb Davies
  • Time estimate: 20 - 30 minutes
  • Difficulty: Moderate
When removing the on/off switch of the compressor, you will first need to remove the shroud. The trick to removing the on/off switch is on the underside of the shroud. This is discussed in the guide.
Sections
Tools
Step 1 Configure the on/off switch for removal  ¶
Twist the On/Off switch from the underside of the shroud. Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
  • Twist the On/Off switch from the underside of the shroud.
  • Twist 90 degrees in any direction or until the on/off switch prongs are in a vertical position.
  • When the switch has reached the correct position, you will feel it "click" into place.
Step 2 Remove the on/off switch  ¶
Push the on/off switch from the underside of the shroud until it comes loose.
  • Push the on/off switch from the underside of the shroud until it comes loose.
  • If the switch is not in the correct position highlighted in the previous step, it will not be easily removed and could damage the shroud.
