Help
Sony FDL-220R Watchman Speaker Replacement
A bad mono-speaker can lead to distorted or no audio on the Sony FDL-220R Watchman. This guide will show you how to replace the mono speaker in order to fix the device's sound.
  • Author: Sam Putnam
  • Time estimate: 30 minutes
  • Difficulty: Difficult
This guide will outline how to replace the Sony FDL-220R Watchman mono-speaker. Steps include a thorough disassembly of the Sony FDL-220R Watchman, and tools include a Phillips #00 Screwdriver, soldering station, and tweezers.
Knowledge of how to solder a basic through-hole contact is required.
Step 1 Remove battery cover and batteries  ¶
Press down on the textured area and push toward the bottom of the device. Gently remove the battery cover.
  • Press down on the textured area and push toward the bottom of the device.
  • Gently remove the battery cover.
  • Remove the three AA batteries.
Step 2 Remove screws  ¶
Locate the five 5x11mm screws surrounding the battery compartment. Remove screws with a Phillips #00 screwdriver.
  • Locate the five 5x11mm screws surrounding the battery compartment.
  • Remove screws with a Phillips #00 screwdriver.
Step 3 Remove back casing  ¶
Grasp the entire back half of the Watchman's casing. Snap off the casing from the bottom of the device.
  • Grasp the entire back half of the Watchman's casing.
  • Snap off the casing from the bottom of the device.
  • Gently pull off entire back casing.
  • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
Step 4 Remove circuit board  ¶
Carefully grasp the entire circuit board. Pull the circuit board off of the device's plastic casing. Pull the circuit board off of the device's plastic casing.
  • Carefully grasp the entire circuit board.
  • Pull the circuit board off of the device's plastic casing.
Step 5 Remove speaker  ¶
Locate the mono-speaker on the device. Locate the two through-hole contacts to the right of the speaker. Touch a soldering iron to the two through-hole contacts.
  • Locate the mono-speaker on the device.
  • Locate the two through-hole contacts to the right of the speaker.
  • Touch a soldering iron to the two through-hole contacts.
  • While the solder is hot, pull down on the wire with tweezers.
  • It may be helpful to remove excess solder with a solder wick or sucker.
