Help
Honeywell HY-204 Rotation Motor Replacement
Potentially Dangerous
Injury may result if this procedure is not followed properly. Use caution and follow all warnings.
Replace a faulty or broken rotation motor.
This guide will walk you through the steps to remove your rotation motor. Though disassembly is simple, it is a difficult process to put back together because you have to solder wires or use a wire connector to reattach a new rotation motor.
Step 1 Rotation Motor  ¶
Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
  • Lay fan on the ground and use your fingers peel the three feet off the bottom of the fan.
Step 2  ¶
Remove the three 12mm screws using the Phillips #0 Screwdriver.
Step 2  ¶
  • Remove the three 12mm screws using the Phillips #0 Screwdriver.
Step 3  ¶
Remove the two 10mm screws using the Phillips #0 Screwdriver. Remove the two 10mm screws using the Phillips #0 Screwdriver.
Step 3  ¶
  • Remove the two 10mm screws using the Phillips #0 Screwdriver.
Step 4  ¶
Move the rotation motor left and right to reveal the screw connecting it to the fan.
Step 4  ¶
  • Move the rotation motor left and right to reveal the screw connecting it to the fan.
  • Remove the 18mm screw from the side of the motor using the Phillips #0 Screwdriver.
Step 5  ¶
Using the wire cutters, severe the wires connecting the rotation motor to the fan.
Step 5  ¶
  • Using the wire cutters, severe the wires connecting the rotation motor to the fan.
  • To put back together you will need to resolder or use wire connectors to reattach motor.
