Help
iPhone 6 Plus Power Button Cable Replacement
Prerequisite Only
Prerequisite Only
Please note that this guide is only a prerequisite for other guides.
Prereq only for removing power button.
Step 1 Power Button Cable  ¶
Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors. Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
  • Use a pair of tweezers to peel the single adhesive tab that resides on top of both the power button and audio control/rocker switch cable connectors.
Step 2  ¶
Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
Step 2  ¶
  • Remove the single 1.3 mm Phillips #00 screw securing the power button cable bracket to the rear case.
Step 3  ¶
Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
Step 3  ¶
  • Carefully grasp the bracket with a pair of tweezers and remove it from the iPhone.
Step 4  ¶
Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
Step 4  ¶
  • Remove the following screws securing the power button cable bracket to the inner edge of the rear case:
  • One 2.1 mm Phillips #00 screw
  • One 1.7 mm Phillips #00 screw
Step 5  ¶
Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
Step 5  ¶
  • Grasp the metal bracket covering the power button switch with a pair of tweezers and remove it from the iPhone.
Step 6  ¶
Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
Step 6  ¶
  • Remove the single 2.1 mm Phillips #00 screw securing the power button switch to the rear case.
Step 7  ¶
Pull the power button switch out of its recess on the rear case with a pair of tweezers.
Step 7  ¶
  • Pull the power button switch out of its recess on the rear case with a pair of tweezers.
