Help
PlayStation 3 Slim Motherboard Replacement
Replace your PlayStation 3 Slim's fried motherboard.
  • Author: Andrew Bookholt
  • Time estimate: 50 minutes - 2 hours
  • Difficulty: Difficult
Use this guide to completely replace your motherboard. Before reattaching the heat sink, be sure to apply a new layer of thermal paste.
Step 1 Motherboard  ¶
Carefully lift the motherboard off the bottom shield.
  • Carefully lift the motherboard off the bottom shield.
  • Handle the motherboard by its edges.
Step 2  ¶
While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
Step 2  ¶
  • While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
  • Failure to hold the plastic retainer down during the prying process may result in it tearing off the motherboard.
  • Before installing the heat sink onto the motherboard, it is essential to apply a new layer of thermal paste. This guide will show you how to do it.
