Help
PlayStation 3 Slim Blu-ray Disc Drive Replacement
Replace a broken Blu-ray drive.
  • Author: Andrew Bookholt
  • Time estimate: 30 minutes - 1 hour
  • Difficulty: Moderate
Use this guide to replace your PS3's Blu-ray disc drive. The drive is a proprietary Sony unit.
Step 1 Blu-ray Disc Drive  ¶
If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive. If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
Step 2  ¶
Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
Step 2  ¶
  • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
  • Be sure you are prying up on the movable retaining flap, not the socket itself.
Step 3  ¶
Pull the Blu-ray ribbon cable straight up and out of its socket.
Step 3  ¶
  • Pull the Blu-ray ribbon cable straight up and out of its socket.
Step 4  ¶
Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
Step 4  ¶
  • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
Step 5  ¶
Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
Step 5  ¶
  • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
Step 6  ¶
Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing. Remove the Blu-ray drive from the PS3.
Step 6  ¶
  • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
  • Remove the Blu-ray drive from the PS3.
  • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
  • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
