Help
Mac mini Mid 2010 Optical Drive Cable Replacement
Replace a broken optical drive cable to restore optical drive functionality.
Replace the optical drive cable if the connector is broken or the ribbon cable itself is damaged.
Step 1 Optical Drive Cable  ¶
Slightly lift the small plastic strip spanning the width of the optical drive.
  • Slightly lift the small plastic strip spanning the width of the optical drive.
  • Carefully de-route the free end of the optical drive connector out from under the optical drive bracket.
Step 2  ¶
Peel the optical drive cable off the body of the optical drive.
Step 2  ¶
  • Peel the optical drive cable off the body of the optical drive.
Step 3  ¶
Remove the optical drive cable by pulling its connector away from the body of the optical drive.
Step 3  ¶
  • Remove the optical drive cable by pulling its connector away from the body of the optical drive.
