Help
Mac mini Mid 2010 Heat Sink Replacement
Replacing the mini's heat sink.
Use this guide to replace your mini's heat sink. Reinstalling the heat sink will require a new layer of thermal paste.
Step 1 Heat Sink  ¶
Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
Step 1 Heat Sink  ¶
  • Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
Step 2  ¶
To disconnect the heat sink thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
Step 2  ¶
  • To disconnect the heat sink thermal sensor, pinch its cables between your thumb and a spudger and pry the spudger upward to lift the connector up and out of its socket on the logic board.
Step 3  ¶
Remove the four 8.5 mm T8 Torx screws securing the heat sink to the logic board.
Step 3  ¶
  • Remove the four 8.5 mm T8 Torx screws securing the heat sink to the logic board.
  • Keep track of the springs held beneath each of the heat sink screws.
Step 4  ¶
Remove the heat sink from the logic board, minding any cables that may get caught.
Step 4  ¶
  • Remove the heat sink from the logic board, minding any cables that may get caught.
  • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
  • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
