Help
Craftsman Model 315.10721 Blade Replacement
Potentially Dangerous
Injury may result if this procedure is not followed properly. Use caution and follow all warnings.
The guide will show the proper steps for replacing the 5/8" blade on the Craftsman Model 315.10721.
  • Author: Riley Hilliker
  • Time estimate: 5 - 10 minutes
  • Difficulty: Easy
Replacing the blade on your Craftsman Model 315.10721 is fairly straightforward. However, replacing the blade can be dangerous, so please take caution when handling the blade and ensure that your saw is unplugged before beginning repair.
Step 1 Blade  ¶
Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
Step 1 Blade  ¶
  • Using a flathead screwdriver, loosen the first 7/32" flathead screw on the saw blade clamp.
  • Rotate the saw blade clamp 90 degrees to the left and loosen the second 7/32" flathead screw
  • It is not necessary to completely remove the screws.
Step 2  ¶
Carefully take the replacement blade and insert it into the saw blade clamp.
Step 2  ¶
  • Carefully take the replacement blade and insert it into the saw blade clamp.
  • To secure the blade, retighten both 7/32" flathead screws on the saw blade clamp.
