Help
MacBook Pro 15" Unibody Mid 2010 Lower Case Replacement
Replace the lower case on your Mid 2010 MacBook Pro 15" Unibody.
  • Author: Walter Galan
  • Time estimate: 3 minutes
  • Difficulty: Moderate
Remove the lower case to access most of your MacBook Pro's internals.
Step 1 Lower Case  ¶
Remove the following ten screws securing the lower case to the upper case:
Step 1 Lower Case  ¶
  • Three 13.5 mm (14.1 mm) Phillips screws.
  • Seven 3 mm Phillips screws.
  • When removing these screws, note how they come out at a slight angle. They must be reinstalled the same way.
Step 2  ¶
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Step 2  ¶
  • Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
