Help
Motorola Droid Motherboard Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Follow this guide to replace your Droid's broken or malfunctioning motherboard.
Sections
Step 1 Motherboard  ¶
Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board. De-route the antenna cable by pulling it out of the metal clips along the side of the front case. De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
  • Use a spudger to pry the antenna cable connectors from their respective sockets on the motherboard and the speaker/antenna board.
  • De-route the antenna cable by pulling it out of the metal clips along the side of the front case.
Step 2  ¶
Peel the black tape covering the side button and display ribbon connectors on the motherboard.
Step 2  ¶
  • Peel the black tape covering the side button and display ribbon connectors on the motherboard.
Step 3  ¶
Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Step 3  ¶
  • Disconnect the power button/volume button connector from its socket on the motherboard using the flat end of a spudger.
Step 4  ¶
Disconnect the  display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Step 4  ¶
  • Disconnect the display ribbon connector from its socket on the motherboard using the flat end of a spudger.
Step 5  ¶
Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
Step 5  ¶
  • Remove three 3.8 mm T5 Torx screws securing the motherboard to the front case.
  • Don't attempt to remove the motherboard yet, it is still attached by the keypad ribbon connector.
Step 6  ¶
Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached. Disconnect the keypad connector by prying it  straight up off its socket on the motherboard.
Step 6  ¶
  • Carefully lift the motherboard from the front case and lay it next to the Droid, minding the keypad connector that is still attached.
  • Disconnect the keypad connector by prying it straight up off its socket on the motherboard.
  • Remove the motherboard from the phone.
