Help
iPhone 6 Plus Front Facing Camera and Sensor Assembly Replacement
Replace the Front-Facing Camera and Sensor Assembly in your iPhone 6 Plus.
  • Author: Walter Galan
  • Time estimate: 1 - 2 hours
  • Difficulty: Moderate
Use this guide to replace the front-facing camera and sensor assembly.
Step 1 Front Facing Camera and Sensor Assembly  ¶
Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly. The cable is held in place with a mild adhesive.
  • Use the tip of a spudger to gently pry up the sensor cable assembly from its recess in the display assembly.
  • The cable is held in place with a mild adhesive.
Step 2  ¶
Pry the microphone portion of the front-facing camera and sensor cables from the display assembly. Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
Step 2  ¶
  • Pry the microphone portion of the front-facing camera and sensor cables from the display assembly.
Step 3  ¶
Remove the front-facing camera and sensor cable assembly off the display assembly.
Step 3  ¶
  • Remove the front-facing camera and sensor cable assembly off the display assembly.
  • Replacement assemblies may or may not come with the speaker mesh already attached. If it's missing, save your old one and re-use it. You can separate it with some heat from a hair dryer and gentle prying or pulling with tweezers.
