Help
iPhone 6 Plus Battery Replacement
Featured Guide
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Replace the Battery in your iPhone 6 Plus.
  • Author: Walter Galan
  • Time estimate: 15 - 45 minutes
  • Difficulty: Moderate
Use this guide to bring life back to your iPhone 6 Plus with a new battery. If your battery is swollen, take appropriate precautions.
This guide instructs you to remove the front panel assembly; this is intended to prevent damage to the display cables. If you feel comfortable supporting the display carefully while peeling the battery out of the iPhone, you can skip the display removal and go directly to the battery removal steps.
For optimal performance, after completing this guide, calibrate your newly installed battery: Charge it to 100% and keep charging it for at least two more hours. Then use your iPhone until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
You can also use this guide to replace the battery connector bracket.
Step 1 Battery  ¶
Peel back the first battery adhesive tab from the bottom right edge of the battery.
Step 1 Battery  ¶
  • Peel back the first battery adhesive tab from the bottom right edge of the battery.
  • Use your fingers or blunt tweezers. Be extra careful when working near the battery; puncturing a lithium-ion battery can release dangerous chemicals and cause a fire.
Step 2  ¶
Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly. Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
Step 2  ¶
  • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
  • Very slowly, pull and stretch one adhesive strip away from the battery, toward the bottom of the iPhone.
  • Allow the strip to stretch out before pulling any harder. If you can't feel it stretching, ease up, or it will break.
  • Pull at as low of an angle as you can without snagging the adhesive strip on any of the components along the lower edge of the phone.
  • Don't press down on the battery as you pull the strip.
  • The strip will stretch to many times its original length. Continue pulling slowly until it releases and slips out from underneath the battery.
  • If the battery adhesive tabs break during the removal process, use your fingers or blunt tweezers to retrieve the remaining length of adhesive, and continue pulling.
  • If any of the adhesive strips break underneath the battery and cannot be retrieved, try to remove the remaining strips, and then proceed as instructed below.
Step 3  ¶
Peel back the second battery adhesive tab from the other side of the battery. Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
Step 3  ¶
  • Peel back the second battery adhesive tab from the other side of the battery.
  • Again, pull and slowly stretch the adhesive tab to slide it out from between the battery and the rear case.
  • Continue pulling the adhesive tab until it releases completely from the battery. If it breaks, try to retrieve the remaining length and continue pulling, or proceed as instructed below.
Step 4  ¶
Peel back the final battery adhesive tab from the bottom edge of the battery. Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case. Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
Step 4  ¶
  • Peel back the final battery adhesive tab from the bottom edge of the battery.
  • Gently pull the battery adhesive tab upward and away from the battery, allowing the adhesive strip to slowly slide out from between the battery and the rear case.
  • Place one hand over the battery as the final strip comes out, or it may fling the battery out of the iPhone.
  • Continue pulling until the final strip comes free from the iPhone.
  • If you removed all three adhesive strips successfully, skip over the next two steps.
  • If any of the adhesive strips broke off underneath the battery and could not be retrieved, continue with the next step below.
Step 5  ¶
If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Step 5  ¶
  • If any of the adhesive strips broke off and the battery remains stuck to the rear case, prepare an iOpener or use a hair dryer to heat the rear case directly behind the battery.
Step 6  ¶
Flip the iPhone back over and insert a plastic card between the left side of the battery and the rear case.
Step 6  ¶
  • Flip the iPhone back over and insert a plastic card between the left side of the battery and the rear case.
  • Don't pry under the topmost section of the battery, near the volume up button and mute switch, or you may damage the audio controls cable, which is adhered to the rear case just beneath the battery.
  • Do not pry against the logic board, or you may permanently damage your iPhone.
  • Be careful to keep the card as flat as possible to avoid bending the battery, which may damage it and cause it to release dangerous chemicals.
  • Press the card in farther to break up the adhesive behind the battery.
  • Alternatively, a piece of dental floss may be used to separate the battery from the rear case. A stronger alternative to dental floss is an unwound guitar string, such as a 0.009 E string from a 12-string set.
  • Thread the floss or string underneath one end of the battery and pull side to side in a sawing motion to separate the adhesive.
Step 7  ¶
Remove the battery from the iPhone.
Step 7  ¶
  • Remove the battery from the iPhone.
  • If your replacement battery came in a plastic sleeve, remove the sleeve before installation by pulling it away from the the ribbon cable.
  • When installing the battery, refer to this guide to replace your battery's adhesive strips.
  • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
