Help
Olympus D590 LCD screen Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Grammar Police
Grammar Police
Embrace your inner English teacher and help improve this guide's grammar!
  • Author: Sara
  • Time estimate: 30 minutes
  • Difficulty: Difficult
This guide will give step-by-step instructions on how to install a LCD screen in a Olympus D590 camera.
Sections
Step 1 LCD screen  ¶
Unscrew the screw shown in the picture from LCD screen.
Step 1 LCD screen  ¶
  • Unscrew the screw shown in the picture from LCD screen.
Step 2  ¶
Remove the side pannel by sliding it off the body of the camera. Lift the camera no more than 3cm to make sure all screws have been taken off.
Step 2  ¶
  • Remove the side pannel by sliding it off the body of the camera.
  • Lift the camera no more than 3cm to make sure all screws have been taken off.
Step 3  ¶
Flip camera so you are looking at the front. Remove gray and blue wiring with tweasers by gently wiggling and pulling.
Step 3  ¶
  • Flip camera so you are looking at the front.
  • Remove gray and blue wiring with tweasers by gently wiggling and pulling.
  • Be careful not to rip the wiring tape with the tweezers.
Step 4  ¶
Locate the tape securing the wiring with the gray end piece located on top of the camera. Gently lift up on the tape till all wires are exposed.
Step 4  ¶
  • Locate the tape securing the wiring with the gray end piece located on top of the camera.
  • Gently lift up on the tape till all wires are exposed.
Step 5  ¶
Flip Camera to the bottom side as shown.
Step 5  ¶
  • Flip Camera to the bottom side as shown.
  • Pull and wriggle the thin yellow wiring tape to detach it from the rest of the camera, while leaving it attached to the LCD screen.
Step 6  ¶
Flip camera so the front is facing you. Locate speaker in upper right hand corner. Gently lift with tweasers.
Step 6  ¶
  • Flip camera so the front is facing you.
  • Locate speaker in upper right hand corner.
  • Gently lift with tweasers.
  • Feed wiring through designated spot so that it is no longer connected to the camera.
Step 7  ¶
Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera. Gently pull the thick yellow wiring out by using the forefinger and thumb.
Step 7  ¶
  • Lift the LCD screen so the thick yellow wiring is the only thing attaching the LCD screen to the camera.
  • Gently pull the thick yellow wiring out by using the forefinger and thumb.
