Help
Nikon Coolpix 3500 Lens Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Replacing the lens of a Nikon Coolpix 3500
Step 1 Lens  ¶
Disconnect the grey-capped wire from the logic board
Step 1 Lens  ¶
  • Disconnect the grey-capped wire from the logic board
  • Disconnect the blue wire attached to the green chip from the center of the logic board
Step 2  ¶
Remove the 3.5 mm screw from the logic board next to the rotating lens Invert the logic board and lens toward the orange and blue wires still connecting the logic board to the LED screen
Step 2  ¶
  • Remove the 3.5 mm screw from the logic board next to the rotating lens
  • Invert the logic board and lens toward the orange and blue wires still connecting the logic board to the LED screen
Step 3  ¶
Disconnect the blue wire connecting the logic board to the LED screen Disconnect the orange wire using a spudger while pushing out horizontally
Step 3  ¶
  • Disconnect the blue wire connecting the logic board to the LED screen
  • Disconnect the orange wire using a spudger while pushing out horizontally
  • Disconnect the red capped wire from the logic board
  • Lift the logic board and lens (still connected) out of the back case
Step 4  ¶
Lift up on the black covering and remove the orange wire connecting the lens to the logic board
Step 4  ¶
  • Lift up on the black covering and remove the orange wire connecting the lens to the logic board
