Help
Nokia 6086 Battery Replacement
  • Author: Andrea
  • Time estimate: 5 minutes
  • Difficulty: Moderate
This guide is a step by step process to remove the battery of the phone. It is a preliminary step to many installation guides.
Step 1 Battery  ¶
Turn off the phone.
Step 1 Battery  ¶
  • Turn off the phone.
  • Check if there is a microSD card in the slot behind the door on the side. If so, remove it by first pushing it in, then pulling it out.
  • Position the phone so that the back side is in view.
Step 2  ¶
Remove the back battery cover. Apply pressure on the cover while simultaneously sliding the cover downward. Apply pressure on the cover while simultaneously sliding the cover downward.
Step 2  ¶
  • Remove the back battery cover.
  • Apply pressure on the cover while simultaneously sliding the cover downward.
Step 3  ¶
Insert the iPod opening tool between the base of the phone and the phone battery. Position the phone so that the battery won't fall out of the phone. The battery lifts out of the phone fast and easily.
Step 3  ¶
  • Insert the iPod opening tool between the base of the phone and the phone battery.
  • Position the phone so that the battery won't fall out of the phone.
  • The battery lifts out of the phone fast and easily.
  • Carefully lift the battery out of the phone.
