Help
Toshiba Satellite M45 Speakers Replacement
Bullets!
Bullets!
Better coordination with markups and the color/type of bullets will help make this guide more clear!
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Confusing Text
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Replacing the internal speakers on a Toshiba Satellite M45.
  • Author: Stephen
  • Difficulty: Moderate
This is a very difficult guide by the average user and is recommended to use headphones or external speakers.
Sections
Step 1 Speakers  ¶
Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires. Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring. Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
Step 1 Speakers  ¶
  • Located near the upper edges of the motherboard you will find the 2-speaker wires that trace to the speakers. You will see these white tab with black and red wires.
  • Unscrew the 2-screws located above the speakers to remove them. Slowly pull up on the speakers as there are other port connectors are located near the wiring.
Step 2  ¶
To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise. Reverse the order after installing the new speakers.
Step 2  ¶
  • To remove the left speaker follow the motherboard repair guide to complete this step to keep this guide concise.
  • Reverse the order after installing the new speakers.
