Help
Disassembling LG VX8550 Front Case
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Missed a Step
Missed a Step
Oops! This guide is currently missing some important steps.
  • Author: Nathan Jones
  • Time estimate: 5 minutes
  • Difficulty: Moderate
Steps to remove the LG VX8550 front case
Sections
Step 1 Front Case  ¶
Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Step 1 Front Case  ¶
  • Remove the 2 screw covers next to the speaker with a push pin next to the camera.
Step 2  ¶
Remove the 6 screws with a Phillips #00 Screwdriver.
Step 2  ¶
  • Remove the 6 screws with a Phillips #00 Screwdriver.
Step 3  ¶
Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
Step 3  ¶
  • Use the ipod opening tool to pry the screen casing and the slider mechanism apart from each other.
Step 4  ¶
Carefully lift the slider mechanism to see the ribbon cables underneath.
Step 4  ¶
  • Carefully lift the slider mechanism to see the ribbon cables underneath.
Step 5  ¶
Slide ribbon cable through the slider mechanism.
Step 5  ¶
  • Slide ribbon cable through the slider mechanism.
Step 6  ¶
Separate the two halves.
Step 6  ¶
  • Separate the two halves.
