Help
HP dv5-1125nr Motherboard Replacement
Scenic Route
Scenic Route
This guide's procedure isn't the most efficient way to get the job done, but still may be useful in some circumstances.
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
This guide explains how to remove the motherboard from the bottom half of the laptop.
  • Author: Nick Loey
  • Time estimate: 30 minutes - 2 hours
  • Difficulty: Moderate
The motherboard holds the CPU and all connectors that let the computer to connect to the outside world. If something fails on it, like the CPU,sound, or graphics card, the computer is rendered useless until the motherboard is replaced.
Sections
Step 1 Motherboard  ¶
Remove the three 3mm Phillips head screws on the top of the frame using the Phillips #00 screwdriver.
  • Remove the three 3mm Phillips head screws on the top of the frame using the Phillips #00 screwdriver.
Step 2  ¶
Using a plastic opening tool, carefully pry off the top plastic cover by lifting it up at the seam at various points around the edge, then remove it completely. Using a plastic opening tool, carefully pry off the top plastic cover by lifting it up at the seam at various points around the edge, then remove it completely.
Step 2  ¶
  • Using a plastic opening tool, carefully pry off the top plastic cover by lifting it up at the seam at various points around the edge, then remove it completely.
Step 3  ¶
Remove the two 2mm screws on the bottom right of the motherboard using the Phillips #00 screwdriver. Remove the two 2mm screws on the bottom right of the motherboard using the Phillips #00 screwdriver.
Step 3  ¶
  • Remove the two 2mm screws on the bottom right of the motherboard using the Phillips #00 screwdriver.
Step 4  ¶
Using the Phillips #00 screwdriver, unscrew the spring-release fasteners on the modem card and remove it from the board. Do not try to remove the modem card from the laptop, it is still attached to the modem connector on the underbody.
Step 4  ¶
  • Using the Phillips #00 screwdriver, unscrew the spring-release fasteners on the modem card and remove it from the board.
  • Do not try to remove the modem card from the laptop, it is still attached to the modem connector on the underbody.
Step 5  ¶
Remove the power cable and two ribbons on the top right side of the board.
Step 5  ¶
  • Remove the power cable and two ribbons on the top right side of the board.
  • These ribbons can be removed by simply pulling to the right of the connector.
Step 6  ¶
Remove the ribbon on the bottom left of the board.
Step 6  ¶
  • Remove the ribbon on the bottom left of the board.
Step 7  ¶
Remove the one 3mm Phillips screw on the bottom left corner of the board using the Phillips #00 Screwdriver.
Step 7  ¶
  • Remove the one 3mm Phillips screw on the bottom left corner of the board using the Phillips #00 Screwdriver.
Step 8  ¶
Make sure to ground yourself to a metal object before attempting to remove the motherboard. Static charge build-up is dangerous to electronics and may ruin your motherboard if not properly grounded.
Step 8  ¶
  • Make sure to ground yourself to a metal object before attempting to remove the motherboard. Static charge build-up is dangerous to electronics and may ruin your motherboard if not properly grounded.
  • Remove the motherboard from the laptop body, being careful to keep the modem board from dislodging itself.
  • Your motherboard is now removed.
