Help
Cambridge Audio A3i Power Cord and Transformer Replacement
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
  • Author: Colby
  • Time estimate: 1 hour
  • Difficulty: Moderate
In this guide we will replace the power cord and the transformer The transformer is the large, heavy device that converts the relatively high 220V input voltage into a lower voltage for the amplifier.
Step 1 Power Cord and Transformer  ¶
Carefully de-solder ends of power cord from circuit board.
  • Carefully de-solder ends of power cord from circuit board.
  • Keep track of the colors of the cords. The brown cord leads to the L on the circuit board, and this cord will lead to a fuse in the power plug. The blue cord leads to the N on the board.
  • Finally, pull the power cord through the rear panel to completely remove it.
Step 2  ¶
To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
Step 2  ¶
  • To remove the transformer the motherboard must be removed. This is to gain access to the solder on the power cords. -See guide for removing motherboard.
  • Remove the 4 nuts holding down the transformer bracket using a 7mm nut driver or socket.
