Help
Canon EOS 6D Rear Body Panel Replacement
Replace the rear body paneling of the EOS 6D.
  • Author: Justin Thomas
  • Time estimate: 20 minutes
  • Difficulty: Moderate
Use this guide to replace the rear body panel of your EOS 6D or to access damaged internal components.
Step 1 Rear Body Panel  ¶
Remove the viewfinder cover by pinching the sides and sliding it upward.
  • Remove the viewfinder cover by pinching the sides and sliding it upward.
Step 2  ¶
Open the battery door on the bottom of the camera.
Step 2  ¶
  • Open the battery door on the bottom of the camera.
  • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
Step 3  ¶
Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
Step 3  ¶
  • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
Step 4  ¶
Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
Step 4  ¶
  • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
  • Rotate the covers to the side so that you can see the connection ports inside.
  • Remove the following screws:
  • Two silver 5mm Phillips #00
  • One black 6mm Phillips #00
Step 5  ¶
Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
Step 5  ¶
  • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
Step 6  ¶
Rotate your camera so the bottom side is facing you.
Step 6  ¶
  • Rotate your camera so the bottom side is facing you.
  • Two 6mm Phillips #00
  • One 3mm Phillips #00
Step 7  ¶
Rotate your camera so the back is facing you.
Step 7  ¶
  • Rotate your camera so the back is facing you.
  • Three silver 5mm Phillips #00
  • Two black 6mm Phillips #00
  • One black 4mm Phillips #00
Step 8  ¶
A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional. Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
Step 8  ¶
  • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
  • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
  • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
