Help
Power and 3.5 mm Audio Adapter Jacks Replacement
This guide describes the process of replacing the Power and 3.5 mm Audio Adapter Jacks.
  • Author: Jerrell
  • Time estimate: 15 minutes
  • Difficulty: Difficult
This guide will show you how to replace the power and 3.5 mm audio adapter jacks on an iHome iP37.
Step 1 Power and 3.5 mm Audio Adapter Jacks  ¶
Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
  • Firmly and cautiously unplug the two white 3-pin connectors from the printed circuit board.
Step 2  ¶
Remove the two 5mm screws holding the power and 3.5mm jack PCB onto the rest of the device; you will need a Phillips #1 driver to do this. Lift the PCB away from the rest of the device. Lift the PCB away from the rest of the device.
Step 2  ¶
  • Remove the two 5mm screws holding the power and 3.5mm jack PCB onto the rest of the device; you will need a Phillips #1 driver to do this.
  • Lift the PCB away from the rest of the device.
Step 3  ¶
Desolder the two black and two red cables from the board.
Step 3  ¶
  • Desolder the two black and two red cables from the board.
  • These wires will need to be soldered to the replacement board when reassembling the device.
  • You can refer to iFixit's guide or this informative video for more information on soldering.
