Help
Motorola V276 Speaker Replacement
  • Author: Kyle Klitzner
  • Time estimate: 15 minutes
  • Difficulty: Easy
This is a guide for replacing the back speaker for a Motorola V276 phone.
Sections
Tools
Step 1 Speaker  ¶
Use Spudger to remove rubber plug from upper left corner of the back of the phone
Step 1 Speaker  ¶
  • Use Spudger to remove rubber plug from upper left corner of the back of the phone
Step 2  ¶
Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Step 2  ¶
  • Using a Hex T6 screwdriver, remove the 4 screws holding the back plate of the phone in place
Step 3  ¶
Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate. Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Step 3  ¶
  • Using your hands, pull up on the back plate while pulling on the 3 side tabs to remove the back plate.
  • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
Step 4  ¶
On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Step 4  ¶
  • On the back casing, using a spudger, push into the headphone jack at an upward angle to pop it out
Step 5  ¶
Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
Step 5  ¶
  • Using tweezers or your hands, pick out the semicircular plastic border between the speaker and headphone jack
Step 6  ¶
Using a spudger, remove the speaker
Step 6  ¶
  • Using a spudger, remove the speaker
