Help
CyberHome CH-DVD 300 Disc Tray Replacement
Replace the disc tray in your CyberHome DVD 300 to repair damage to the disk tray.
  • Author: Chris Menezes
  • Time estimate: 15 minutes
  • Difficulty: Moderate
Replacing the disk tray requires you to first remove the top and back panels of the DVD player, locate the black disk tray, and slide away the disk tray
Step 1 Disc Tray  ¶
Remove the four 8.1mm screws in each of the corners of the disc tray. Remove the four 8.1mm screws in each of the corners of the disc tray. Remove the four 8.1mm screws in each of the corners of the disc tray.
Step 1 Disc Tray  ¶
  • Remove the four 8.1mm screws in each of the corners of the disc tray.
Step 2  ¶
Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly. The faceplate is located on the front of the DVD player and will prevent the disc tray removal if not removed.
Step 2  ¶
  • Orient the device so the front is facing towards you. Remove the disc tray faceplate by lifting up on both corners firmly.
  • The faceplate is located on the front of the DVD player and will prevent the disc tray removal if not removed.
Step 3  ¶
Detach the ribbon cable from the side of the DVD player by gently pulling it out. Detach the ribbon cable from the side of the DVD player by gently pulling it out.
Step 3  ¶
  • Detach the ribbon cable from the side of the DVD player by gently pulling it out.
Step 4  ¶
Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
Step 4  ¶
  • Orient the device so the back is facing towards you. Remove the disk tray out towards the back of the DVD player by lifting it.
