Help
LG CG225 Rear Cover Replacement
Action Shots
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Replace the rear cover from your LG CG225.
  • Author: Darlena
  • Time estimate: 5 minutes
  • Difficulty: Easy
This guide explains how to remove the back cover from your LG CG225.
Step 1 Rear Cover  ¶
Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
Step 1 Rear Cover  ¶
  • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
Step 2  ¶
Remove a single Phillips #00 screw from beneath the cover.
Step 2  ¶
  • Remove a single Phillips #00 screw from beneath the cover.
Step 3  ¶
Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
Step 3  ¶
  • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
