Help
Dell Latitude D620 RAM Replacement
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
  • Author: Miguel Wong
  • Time estimate: 10 minutes
  • Difficulty: Moderate
Guide to installing new RAM modules for the Dell Latitude D620.
Step 1 RAM  ¶
With the keyboard removed, you should be able to see ram slot A. Place new ram into the slot making sure it is aligned
Step 1 RAM  ¶
  • With the keyboard removed, you should be able to see ram slot A.
  • Place new ram into the slot making sure it is aligned
Step 2  ¶
Replace the keyboard by following the previous steps in reverse
Step 2  ¶
  • Replace the keyboard by following the previous steps in reverse
  • Close the laptop, and flip it over onto its backside
Step 3  ¶
Loosen the screw that holds the RAM cover in place. The screw cannot be fully removed since it is attached to the RAM cover.
Step 3  ¶
  • Loosen the screw that holds the RAM cover in place.
  • The screw cannot be fully removed since it is attached to the RAM cover.
Step 4  ¶
Insert new ram into slot B Insert new ram into slot B
Step 4  ¶
  • Insert new ram into slot B
