Help
IBM ThinkPad R40 Fan Replacement
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Markup Mishap
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Better Introduction
Better Introduction
Improve this guide by completing or revising its introduction.
This guide will help users replace the IBM ThinkPad R40 laptop's onboard cooling fan.
  • Author: Aaron
  • Difficulty: Easy
Step 1 Fan  ¶
Remove the screws shown. These screws are connected to the keyboard.
Step 1 Fan  ¶
  • Remove the screws shown. These screws are connected to the keyboard.
Step 2  ¶
Take the spudger tool,  go around the edges of the oranges boxes shown, and pop off those two sections. Then, go around the edges of the keyboard, and it should slide off.
Step 2  ¶
  • Take the spudger tool, go around the edges of the oranges boxes shown, and pop off those two sections. Then, go around the edges of the keyboard, and it should slide off.
Step 3  ¶
Lift and move keyboard aside to get to screws. Try not to remove the attached ribbon. Remove the screws shown. These screws will allow you to loosen the fan. Be careful since there is still another part connected.
Step 3  ¶
  • Lift and move keyboard aside to get to screws. Try not to remove the attached ribbon.
  • Remove the screws shown. These screws will allow you to loosen the fan. Be careful since there is still another part connected.
Step 4  ¶
Carefully unplug the highlighted part, and your fan should come straight out.
Step 4  ¶
  • Carefully unplug the highlighted part, and your fan should come straight out.
Step 5  ¶
The section in blue is where your new fan will go.
Step 5  ¶
  • The section in blue is where your new fan will go.
