Help
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Incorrect Tools
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
  • Author: Thomas
  • Difficulty: Moderate
This guide will show you how to access the LCD screen in order to repair or replace the screen.
Step 1 LCD Screen  ¶
Remove the two screws holding the circuit board down. Remove the two screws holding the circuit board down.
Step 1 LCD Screen  ¶
  • Remove the two screws holding the circuit board down.
Step 2  ¶
Detach the orange cable from the board.
Step 2  ¶
  • Detach the orange cable from the board.
  • Use a thin object, like a paperclip, to gently pry the cable off the connector.
Step 3  ¶
The LCD screen sits in two slots; one on the bottom, and one on the left edge. Slide LCD screen from the two slots.
Step 3  ¶
  • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
  • Slide LCD screen from the two slots.
  • Do not attempt to completely remove the screen, as it is still attached to the camera.
Step 4  ¶
To remove the LCD screen, detach the orange cable from the board. If needed, replace the LCD screen. If needed, replace the LCD screen.
Step 4  ¶
  • To remove the LCD screen, detach the orange cable from the board.
  • If needed, replace the LCD screen.
