Help
PowerBook G3 Pismo Processor Replacement
  • Author: iRobot
  • Difficulty: Easy
This processor is not soldered to the logic board, and installing a replacement is very easy. There are processor upgrades that enable you to turn your Pismo into a G4.
Step 1 Processor  ¶
Grasp the plastic tab on the processor's right side and pull it directly up.
Step 1 Processor  ¶
  • Grasp the plastic tab on the processor's right side and pull it directly up.
  • Some processors may be missing the plastic pull tab. In this case, we suggest using a non-metal tool to gently pry up the processor. Slip the tool's thin edge under the front right corner of the processor and carefully pry it up.
Step 2  ¶
Your laptop should look approximately like this.
Step 2  ¶
  • Your laptop should look approximately like this.
