Help
LG VX5200 Rear Body Panel Disassembly
A few steps to remove the back of the phone.
Step 1 LG VX5200 Rear Body Panel Disassembly  ¶
Orient the phone as shown with the battery already removed.
  • Orient the phone as shown with the battery already removed.
Step 2  ¶
Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards. Use a Phillips #00 screwdriver to remove the 5 screws as shown here. Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Step 2  ¶
  • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
  • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
Step 3  ¶
Place an iPod opener tool in the seam above the antenna. Run the tool around the perimeter of the entire phone. Run the tool around the perimeter of the entire phone.
Step 3  ¶
  • Place an iPod opener tool in the seam above the antenna.
  • Run the tool around the perimeter of the entire phone.
Step 4  ¶
Check to see that your device looks like the attached photo.
Step 4  ¶
  • Check to see that your device looks like the attached photo.
