Help
Rival Mini Chopper MC-67BL Turning Gears Replacement
Remove the turning gears of the Rival Mini Chopper.
  • Author: Roxanne
  • Time estimate: 10 minutes
  • Difficulty: Moderate
This guide will help you remove the turning gears of the Rival Mini Blender. Removing the gears will allow you to access the interior components of the device.
Step 1 Turning Gears  ¶
Twist the plastic lid counterclockwise to unlock it. Lift the lid to remove it from the container.
  • Twist the plastic lid counterclockwise to unlock it.
  • Lift the lid to remove it from the container.
Step 2  ¶
Carefully remove the blade from the container.
Step 2  ¶
  • Carefully remove the blade from the container.
  • For reassembly, the teeth on the metal shaft line up with slots on the inside of the plastic hole.
Step 3  ¶
With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Step 3  ¶
  • With your hand, twist the container counter-clockwise until it unlocks from the base. Remove the container by lifting it straight up.
Step 4  ¶
Use your fingers to pry out the two rubber feet from the bottom cover of the base.
Step 4  ¶
  • Use your fingers to pry out the two rubber feet from the bottom cover of the base.
  • The two feet furthest from the button tower contain screws. The other two feet do not.
Step 5  ¶
Use the Phillips #2 screwdriver  to unscrew the two 12.7-mm screws underneath the rubber feet. Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Step 5  ¶
  • Use the Phillips #2 screwdriver to unscrew the two 12.7-mm screws underneath the rubber feet.
  • Use the same screwdriver to unscrew the 15.88-mm screw from the back of the chopper.
Step 6  ¶
Firmly lift the bottom cover off of the base.
Step 6  ¶
  • Firmly lift the bottom cover off of the base.
Step 7  ¶
Remove the smaller white gear by lifting it up with your hand.
Step 7  ¶
  • Remove the smaller white gear by lifting it up with your hand.
Step 8  ¶
Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base. Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin. Continue turning the gear until completely removed from the blade-shaft.
Step 8  ¶
  • Use a pair of pliers or any other clamping tool to securely hold the blade-shaft that sits above the base.
  • Grab the gear with your other hand and turn CLOCKWISE. Unlike most screws, the gear is reverse-threaded to allow the blade to spin.
  • Continue turning the gear until completely removed from the blade-shaft.
