Help
Canon ImageCLASS MF4350d Replace Scanner Glass Replacement
Needs Better Images
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
If there is something wrong with your scanner's glass, this guide will help you fix it and start scanning in no time.
This guide will help you to replace your scanner's glass. You may need to replace the glass if the glass has noticeable scratching, the glass is broken, or if the glass is cracked. IMPORTANT: If the glass is broken take extreme precaution in replacing the glass. Broken glass can cause damage to you and things around you. Also, if you are getting smudges when you scan in items make sure that the glass does not have any fingerprints, smudges, or dust on it. You may need to clean your glass with glass cleaner.
Step 1 Replace Scanner Glass  ¶
Take out the damaged glass and fit the replacement glass to the printer according to the picture.
  • Take out the damaged glass and fit the replacement glass to the printer according to the picture.
